Brinell Hardness Test (HB)
Q. What is the HB for the cadmium plated (Cd10) the material no. is (1.7734.4) and protected by (Cd10)......?
Ahmed Ragab (third year...Aerospace department)
Ahmed Ragab Moh. Owis
student (Aircraft Engineering) - 15th May, Cairo, Egypt
A. DIN alloy steel 1.7734.4 (1.7734, air-cooled condition) has a yield strength of 550 MPa and a tensile strength of 700 MPa (101.5 ksi). This tensile strength equates to a Brinell hardness 215 (from ASTM A370, Table 3).
The cadmium plating is presumably softer. To measure its hardness, a sample can be cut, mounted and polished with plating perpendicular to the polished surface (see ASTM E3 for metallographic preparation). Then, the plating's microhardness can be measured using a Knoop or Vickers indenter (see ASTM E384).
Ken Vlach [deceased]
- Goleta, California
