Need advice on Finishing/Protecting steel
Hello, I need advise on how best to finish and protect steel table-tops I am making for a restaurant. Any process or product information is appreciated. I am looking for a way to make the metal look somewhat dark/aged (black oxide?) and then provide a protective coating which can resist rusting/cleaning and the everyday abuse of restaurant use. Appreciate any response as I need HELP!
Robert T. ParkerJuniper Designs - Norfolk, Virginia USA
The process you describe will work and could be done relatively locally.
Black oxide is normally oiled, so your painter would have to be moderately close by.
Consider a zinc phosphate and lacquer, possibly colored.
For long term durability, I would investigate powder coating with an antiquing finish. It is mind boggling what they can do with powder now.
James Watts- Navarre, Florida
