Aluminum galling
I have CNC'd two pieces of aluminum to make a portable espresso machine.
The bottom is 2.3" diameter. The top is 3" diameter.
The top and bottom pieces gall so bad that they will not open. What can I do?
I tried FDA approved anti seize, but it looks gross, and I don't think consumers will want to see it while they make espresso.
If I was going to use a different metal for the lid, what should I use?
Water is pressurized to 160 PSI and heated to 212 °F deg.
Please help
What kind of aluminum should I buy?
Soren Brockdorf
- Jacksonville, Florida, USA
Hard or even conventional anodizing both parts may help or even totally eliminate your problem. Electroless nickel plating may also be a solution though probably more expensive.
Guillermo Marrufo
Monterrey, NL, Mexico
Does the top thread onto the bottom (cylinder, maybe)?
The problem could be tapered (pipe) threads --shouldn't use where frequent disassembly is necessary. Use machine threads (straight), anodized, and seal with a suitable o-ring.
If problems with a non-threaded assembly, anodizing may prevent the galling.
Note there will be a build-up per surface of about 1/2 the anodize thickness.
What aluminum alloy are you now using?
If hard water scale can occur, using stainless steel will allow cleaning with the common acidic scale removers.
Ken Vlach [deceased]
- Goleta, California
