CHROME OR RHODIUM PLATING ALUMINUM
WE WANT TO PLATE AN ALUMINUM PRODUCT USED IN THE MARINE INDUSTRY . WE WANT IT TO BE PROTECTED AS GOOD AS POSSIBLE .WITH A COST FACTOR, WHAT IS THE BEST WAY TO PLATE ALUMINUM TO LAST IN THE ELEMENTS, OF SALT WATER.
ROB MCKAY
- VAN, B.C., CANADA
Hi Bob,
It would be much more expensive to plate Rh, especially with the thickness required for salt water applications. The Rh deposit would be too stressful. I have seen good results with a microcracked hard chrome (bright), with a sulphamate Ni underplate. Good Luck!
Mark Baker
Process Engineer - Syracuse, New York
Forget Rhodium. It cracks and then the seawater will undercut the deposit and lift it right off. In seawater, nothing beats Cadmium. I heard that Zinc-Nickel alloy was supposed to replace Cad, but I don't know how far that's gotten.
Dave Kinghorn
Dave Kinghorn
Chemical Engineer
SUNNYvale, California
