Corrosion of brass stud in aluminium, carrying DC current
Hi my name is Frank Flinders
I have a problem with a bad electrical joint developing in a brass stud taped into an aluminium body.
Is there potential for corrosion between a brass stud screwed into a threaded aluminium body. The stud carries a high level of DC electrical current. Electron flow is from the Aluminium to the brass.
Frank Flinders
- Brisbane, QLD, Australia
"No-Ox-Id" Compound
no_ox_id
Hi Frank,
The aluminum will galvanically corrode in the presence of moisture.
To prevent, use electrical joint compound (EJC) on the stud threads before inserting. EJC's are waterproof greases (or wax for high T), contain corrosion inhibitors, some can dissolve surface oxides and some have fine zinc particle filler for improved conductivity. Use one rated for aluminum-to-copper connections (and high temperature if applicable). Some brands are Alcoa #2 & Alnox, Burndy (Penetrox A & A13), Hubbell (Anderson # VS8HTJC), and NO-OX-ID 'A-Special.'
For more information, see 'ELECTRICAL CONNECTIONS FOR POWER CIRCUITS' from the US Bureau of Reclamation:
http://www.usbr.gov/power/data/fist/fist3_3/vol3-3.pdf
Also, check applicable electrical codes.
Ken Vlach [deceased]
- Goleta, California
Aluminium will corrode when contacted by brass. You may need to Bronze plate the Brass, Bronze will not initiate any corrosion in the Aluminium.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
thumbs up sign Thank you for your very useful replies. We have used a jointing compound to exclude the possibility of ingress of any moisture.
Frank Flinders [returning]
- Brisbane, Australia
