What is Ford plating spec S900?
We are a plating co in Ohio and were asked to quote a plating job to a Ford spec S900 if you could please research this spec back to us we would really appreciate it. Thank you,
Rick Szymanowski
polishing and plating - Toledo, Ohio, USA
S900 is a designation that appears in Ford Worldwide Fastener Standard WX100 Finish Specification. It denotes a special finish that is identified on the part drawing. There are no specific requirements such as coating material, thickness, etc. These are supposed to be identified on the part drawing.
Toby Padfield
Automotive module supplier - Michigan
