How to remove oxidation from galvanized metal
Is there some combination of vinegar, baking soda, or sulfuric acid or another acid that can be applied to galvanized tin to make it shine as original?
Wendell Custer- Cushing, OK
You can use 5% hydrochloric acid (you can add 1 gm gelatin to 1 liter solution). Rinse well! Good luck!
