How to prepare passivation solution for SS304 fabricated parts to avoid rust
We are facing a problem of Rust on SS 304 fabricated parts. These parts are meant for the use in Railway industry and most of these are brackets and nut plates.
Our suppliers are not very familiar with passivation process, so I want to know how to prepare the Passivation solution. Basically I need inputs regarding composition and mixing methodology.
Ajmal
- Dubai, UAE
With 304 SS, a relatively simple passivation in 25-45 vol% nitric acid for 30 minutes at 21-32 C, followed by rinsing in clean water, is commonly used. The difficulty with fabrications is removing weld scale and cleaning prior to passivation. See ASTM ASTM A380 , 'Standard Practice for Cleaning, Descaling, and Passivation of Stainless Steel Parts, Equipment, and Systems.' This also mentions methods to minimize iron contamination of SS during fabrication.
Ken Vlach [deceased]
- Goleta, California
Passivation with commercially available citric acid formulations according to ASTM A967 should give you what you need without exposure to hazardous chemicals. Contact us if you need help.
lee kremer
lee kremer sig
Lee Kremer
Stellar Solutions, Inc.
McHenry, Illinois
stellar solutions banner
www.finishing.com is made possible by supporting advertisers ...
