How long does galvanized plating last?
Lynda Smith-BarryTampa, Florida
It lasts a long time, Lynda, but the exact number depends on the thickness and the exposure conditions. But usually 25 years and up if you are speaking of open air rather than immersed in water or in the ground.
Also the zinc coating thickness is important.
In a non-coastal and non-polluted area each micron of zinc counts for approximately one year of service life.
Passivation of the zinc coating will extend this.
coil coating - Heijningen, The Netherlands
Recent UK research shows a life of up to 170 years in a rural environment for a standard galvanized coating.
You can check this out at the UK Galvanizers association website where there's a map showing life expectancy across the UK. Transferring this data to your location might be erroneous, but it will give you an idea.
Geoff Crowley
Crithwood Ltd.
Westfield, Scotland, UK
