Scratches in brass belt buckle!
Hey guys I'm in 10th grade and in ROTC.. have scratches on my brass buckle.. Not sure how they got there.. But they are.. -cries- This is my first time in uniform and I don't want to mess it up..
Anyways.. Dose anyone have any ideas on how to get them off?
Fox
ROTC - Panama City, Florida, USA
In days of old, after polishing the brass, we would coat them with fingernail polish to keep them bright and shiny. You may have a clear coat on yours that is scratched. The clear coat might be able to be removed with a solvent like alcohol or acetone ⇦ on eBay or Amazon [affil link] Flammable! . If the metal is scratched, it will be a long process to get it back to desired. It will be quickest and cheapest to just buy a new buckle.
Second of two simultaneous responses -- 2006
Hi Fox,
The answer to removing scratches in your brass buckle is to grind them down.
Ideally, you should have a rotating cloth wheel, say around 1/2" or more in thickness, then use a 'grinding compound', ideally jeweler's rouge ⇦ on eBay or Amazon [affil link] , but if you haven't got that, then, after sanding down that scratch, use finer and finer sandpaper or emery paper and THEN go the final polish using Brasso ⇦ on eBay or Amazon [affil link] or some commercial brass cleaner.
Wow, do they have a R.O.T.C. in Panama ?...I used to belong to one back in the Middle Ages where we had to wear puttees instead of gaiters.
freeman newton portrait
Freeman Newton [deceased]
