Helicopter Pad, appropriate paint
What would be an appropriate paint system for a helicopter pad? Is there a minimum requirements for paint thickness?
Nabil Mabrouk
Architectural and Engineering Consultants - Abu Dhabi, United Arab Emirates
I would assume epoxy non-skid by maybe you could find here
www.dodcorrosionexchange.org/
Jim Wood
- Concord, California, USA
I would suggest using a 2 part epoxy. Imron is what I used on a garage floor which has lated for over 12 years. Be sure to broadcast the surface with silica sand for slip resistance.
Kerry Kirsch
- Troy, Michigan, USA
