Metal roofing ground contact
Can galvanized roofing be used to cover foundation insulation - that is, in contact with the ground?
Sam Clark
design - Plainfield, VT, USA
Galvanizing is used on things that are in direct contact with the ground like ground rods, but sheet metal even with a galvanized coating will have a relatively short life in ground contact.
