Want to create a "brushed" metal look on a spray painted lamp
I have refinished a metal lamp (unknown type of metal). I have sanded spray painted & applied clear lacquer finish. Results unsatisfactory--lamp looks cheap. I would like to create a "brushed" surface. I have a Dremel this on eBay or Amazon [affil links] tool with many attachments.
I would appreciate your advice.
Sincerely,
Susan Seitter
Hobbyist - Corpus Christi, Texas
The answer is simpler than you think, use a sponge to dab on a metallic paint then using a stiff bristled brush (a deck brush would probably work best) add the pattern however you want.
Marc Banks
Blacksmith - Elizabeth City, North Carolina
