Determine the concentration of hypophosphorous acid in presence of tin
I need to measure the concentration of hypophosphorous acid in the plating bath with the presence of Sn+2. Anybody know how to eliminate Tin out of the solution and measure the concentration of hypophosphorous acid?
The concentration of hypophosphorous acid is about 50-120g/L and the tin concentration is about 25-70g/L.
Gtong
student - Hong Kong
I would filter the sample carefully, then do a titration with either standard iodine or iodate solution. This gives you the combined Sn2+ and hypophosphite concentration.
Then, I would determine the tin concentration via AA spectroscopy ⇦ on eBay or Amazon [affil link] , and get the hypo result by difference. If I did not have an AA, I would assay the tin by a gravimetric method using cupferron as precipitant, followed by ignition of the precipitate, and weighing the resultant SnO2.
dave wichern
Dave Wichern
Gtong -
Maybe this is a dumb idea, but could you get an idea of the hypophosphorous acid simply by doing an acid-base titration? Then you wouldn't need to eliminate the Sn+2 interference. I don't have any experience with this acid, but I see that is is classified as a powerful reducing agent.
Terry Tomt
- Auburn, Washington
