Alodine 1200S for Low Resistance Coating per AMS 2474 ?
Can I use Alodine 1200S for low resistance coating per AMS2474?
* Ed. note (copied from SAE Standards Works): "AMS2477 was written to be the successor document to AMS2474 because the latter contains certain testing frequencies, equipment, and conditions which are impractical and a full revision to remove same from AMS2474C was precluded by Committee B."
Samples for testings must be made from 2024 T3 material.Resistance must be less than 5000 microohms per square inch.
Adam Baran
(aerospace) - Rzeszow, Poland
