Thread 425/64
Removal of heat scale from annealed electroless nickel deposit
I am looking for a solution to clean the coloration produced on the mid phosphorous electroless nickel deposit on copper pieces. Medium phosphorous electroless nickel (about 300 microinch) was deposited on about 1 square inch copper pieces and then heat treated at 400 °C for
1 hour. Unfortunately, the heat treatment at 400 °C tarnished the electroless nickel plating (to a bluish grey color). I need to remove this heat scale so that the normal nickel finish is restored on these slugs.
Can anyone please help me in finding a method to remove this scale without damaging the underlying nickel and the base metal?
- Skokie, Illinois, USA
publicly reply to Sandy Kumar
Dear Sandy:
Unfortunately, there is no chemical method for removing the discoloration on EN coatings produced by heat treatment at temperatures over 300 °C. It can only be removed by abrasion cleaning by blasting, thumbing, etc.
You can sometimes plate a flash coating of new EN over the old coating to hide the discoloration, but it probably will not adhere.
Sorry.
Ron Duncan [deceased]
- LaVergne, Tennessee
It is our sad duty to note Ron's passing on Dec. 15, 2006. A brief obituary opens Episode 13 of our Podcast.
publicly reply to Ron Duncan
I agree with Ron Duncan. It is difficult to remove the discolouration formed during heat-treatment.
Maybe you can try to heat-treat your components in inert atmosphere?
T.S.N. Sankara Narayanan
- Chennai, Tamilnadu, India
(ed.note: The good doctor offers a fascinating blog, "Advancement in Science" )
publicly reply to T.S.N. Sankara Narayanan
