Need to remove Silicon[e] spray
I need something to clean silicon spray from my carport so I can repaint.
Henry Lovvo
homeowner - Lady Lake , Fl, USA
I presume you mean silicone, Henry. This is impractical to chemically remove, so professional paint shops forbid it being brought into their buildings. I'd recommend detergent plus pumice this on eBay or Amazon [affil links] scrubbed over the surfaces with a tampico brush, and hoping for the best.
There are several silicone removers on market: Slide silicone remover is just one of them. One do it yourself mix:
10 ml dodecylbenzene sulfonic acid
8 ml dichlorometane
5 ml toluene
18 ml Xylene this on eBay or Amazon [affil links]
Hope it helps and good luck!
- Croatia
