Stripping zinc phosphating layer from iron
Hi
I need to know the components for alkaline stripping of zinc phosphating layer from iron.
I should use alkaline cleaner for removing zinc phosphating. I used NaOH + KOH AND
trisodium phosphate
⇦ this on
Amazon [affil links]
but I not received a good answer from this material .
- Iran
Ammonium hydroxide mixed with ammonium dichromate works good. Mix 44 g of the ammonium dichromate powder with an imperial gallon of ammonium hydroxide.
Ronald ZeemanCoil Coating - Brampton, Ontario, Canada
