Zinc Plating Specification ASTM A164
Plating spec. question: what is the below plating definition?
ZINC PLATE PER ASTM A164 TYPE RS OR EQUIVALENT
plating thickness? any Chromate coloring? Is it commercial?
fastener mfg. - Worcester, Massachusetts
Sorry, never heard of it. I don't claim to have heard of everything, of course, but if no one gives a more positive response either, perhaps there is a typo in the spec number.
An internet search quickly determined that in 1981 this spec was canceled and replaced with the current ASTM B633. The link with the information is: https://www.astm.org/cgi-bin/SoftCart.exe/DATABASE.CART/WITHDRAWN/A164.htm?E+mystore
Milt Stevenson, Jr.
Syracuse, New York
ASTM A164 is not a current specification was replaced in 1985 by ASTM B633. I believe that type RS was the thinnest of the specified zinc coatings and was approximately .00015 inches. The other thicknesses were type LS and GS. I think chromate was addressed in another part of the spec.
John C WilliamsNutec Metal Finishing - Birmingham, Alabama
Several reference books confirm John's thickness info for ASTM A164-40T, -49, -55:
"The minimum thicknesses on significant surfaces...are
"G.S.," 0.025 mm (0.0010 in.);
"L.S.," 0.013 mm (0.0005 in);
"R.S.," 0.0038 mm (0.00015 in.).
...The "R.S." coatings are suitable only for indoor or temporary use."
Modern Electroplating, Allen G. Gray (ed.), p. 457 (1953).
- Goleta, California
