THE EFFECTS OF FLUORESCENT LIGHT ON BLACK OXIDE FINISH
MY NAME IS CHAD BOGDAN, I WORK FOR A SHEETMETAL FABRICATOR IN WHITE BEAR LAKE MINNESOTA, MY QUESTION TO YOU IS.
OUR QUALITY MANAGER SAID SOMETHING THE OTHER DAY THAT JUST SOUNDED FAR FETCHED, HE SAID THAT FLUORESCENT LIGHTING CAN CAUSE THE BLACK OXIDE FINISH TO FADE OR DISCOLOR, IS THIS TRUE.
CHAD WILLIAM BOGDAN
- WHITE BEAR LAKE, Minnesota
No, but water can turn it to red rust.
Your manager may be thinking of dyed anodized aluminum.
Ken Vlach [deceased]
- Goleta, California
Real black oxide on iron or steel is not sensitive to light.Hope it helps and good luck!
