High temperature resistant plating process
I am seeking a high temperature resistant plating process to apply to exhaust outlets on a aero engine, it will need to be dark grey to black in colour and hard wearing as they are exposed to both the high exhaust temps and also airflow.
COLIN SWANN
- UNITED KINGDOM
Black chromium plating seems a good choice as the coating has good corrosion/wear resistance and has high thermal stability.
David Shiu
David Shiu
