Acid Pickling: hydrochloric vs. phosphoric acid
Q. We are using hydrochloric acid for pickling. But we wanted to use orthophosphoric acid for pickling. But HRCA scales are not removed properly by phosphoric acid. So shall we use a combination of HCl and H3PO4? If so, kindly let me know the ratio. Thanking you.
S.V. Aurobind
plating process supplier - Bangalore, India
A. Hi,
In fact there is no use of phosphoric acid if you are using the same with HCl. Better you use HCl with suitable Inhibitor and a dip in 30% phosphoric acid bath after water rinse to get the phosphate ions over the metal surface.
Navin Maheshwari
- New Delhi, India
A. It is better you use phosphoric acid 43% with 7% H2SO4 + TRIETHANOL AMINE 5% + BRICORR 288 OR STANNINE FROM RHODIA COMPANY 0.25% (anti corrosion) + NONY PHENYL ETHOXILATE 0.5% + WATER.
Farshid Farzanegan
manufacturer for PT material - Tehran, Iran
A. If you ask about steel pickling you can use hydrochloric acid only with Inhibitor to remove the scale and corrosion without any etching to the steel surface at room temperature at 30 - 40 % with a good ventilation.
Ali Gomaa
- Cairo, Egypt
Q. Would someone happen to know why hydrochloric acid is prefered rather than phosphoric acid for pickling? Additionally, what sort of Iron phosphate precipitate forms when pickling with phosphoric acid?
Howard Bosae
- vanderbijlpark,Gauteng, South Africa
October 10, 2014
A. Hi Howard. HCl is more aggressive than other acids like phosphoric, so it is preferred as being a more capable pickling agent. The problematic term, however, may be 'pickling' ... to some people it means removing heavy scale, while to others it means a mild acid dip. I'm not sure of the exact compounds formed, but phosphoric acid converts red rust to black rust, whereas proprietary iron phosphate solutions may contain various modifiers, as well as incorporating cleaning agents.
October 2014
A. HCl is somewhat cheaper. A drum does not weigh as much. The spent phosphoric tends to slime up the waste water treatment system.
The chlorine gas and the HCl mist are 2 drawbacks.
Q. Thank you all.
The reason I was asking about phosphoric acid is because for our galvanizing acid dip line we use 16-30% HCl and pickling we use 16% HCl.The problem we are experiencing is from our effluent plant as we pick up high chloride concentration and electrical conductivity as a results of using HCl in our process.
Howard Bosae
October 15, 2014
A. Don't know about your jurisdiction, but usually regulations are much more permissive of chloride than phosphate which causes eutrophication.
Pickling steel in phosphoric acid
Q. I am planning to conduct pickling for a carbon steel pipe using phosphoric acid. Could you please advise on what surfactant can I use for this process. Thank you
Lokesh Naga
- Selangor Malaysia
October 20, 2017
A. Hi Lokesh. We appended your inquiry to a thread where Farshid Farzanegan offers his suggestion.
But you may or may not be using the word "pickling" the same way that I would use it. Please explain what you are trying to accomplish by dipping the carbon steel pipes into phosphoric acid, i.e., what condition they are in or what steps they've been through before the pickling, and what your intended next step will be after pickling, whereby you feel dipping them into phosphoric acid is appropriate at that point. Thanks.
October 2017
