Chrome plating thickness
My print calls for plating brass: "polished chrome plate per ASTM B456 -91a condition 2 min. How thick will this plating be?
Rob Reed
Premier Machine Products - Kirtland, Ohio
You really need a copy of the Spec. as there probably are other quality issues as well that you must comply with to certify the plating.
