Using pure bismuth to coat copper
I would like to bond bismuth to copper for a special proprietary application and was wondering if this is feasible. Is it as easy as using flux and basically melting the bismuth onto the copper, as if I were soldering? What I'd like to do is pour or apply molten bismuth onto a copper surface and have it adhere. Where should I begin?
Thanks for any responses.
Mechanical Engineering - Kansas City, Missouri, USA
Bismuth fumes are very bad for the human body, so approach with caution. Something like a fume hood probably should be used.
You do not mention part size. This would make a big difference.
You probably could use a plumber furnace and an appropriate pot. I would guess that sanding the copper and a quick dip in
muriatic acid
⇦ this on
Amazon [affil links] should allow it to work like old fashioned leading. (LED)
You can brush plate Bismuth onto metals such as copper. We have been doing this for a number of years on a limited amount of parts as the application is unusual.
This is an electrolytic process so no heating of the bismuth metal is required.
- Valencia, California, USA
