Gold plated slip rings
Is someone familiar with gold plated slip rings?
The plating should withstand the constant rubbing of 80%silver, 20% graphite contacts.
Any information will be greatly appreciated.
Florencio Canizales
Mfgr - Austin, Texas
Is you interest just intellectual, or are you trying to buy new rings or fix the ones you alrerady have? For friction and spark resistance, platinum is better than gold and not too much more expensive. Both metals are routinely plated by dedicated companies, either by immersion or brush. Both require an underplate or initial strike of a different metal before plating, depending on the substrate.
Guillermo Marrufo
Monterrey, NL, Mexico
I want to reduce cost by replacing coin silver rings whenever possible.
Florencio Canizales
- Texas
