I am try to find out root cause of flake on the edge at the contact point of Dull Ni plating
Now in my current process have problem about flake at the edge on contact point.
It effect to part quality and take long time to inspection and remove flake .
heat spreader - Chonburi, Thailand
This "flaking" could be high current density burning or a problem in your cleaning cycle. It is too hard to say without more information. Are the parts barrel plated? What is the substrate material, pre-clean and pre-plate process, current density in matte Ni? Is the metal concentration in the bath where it should be? Let us know some details.
Mark BakerProcess Engineer - Syracuse, New York
