Does 35% H202 need to be stabilized for a hot tub? If so, with what?
I want to use hydrogen peroxide as a sanitizer for my hot tub so I don't have to use Chlorine. What makes H202 volatile? Does 35% H202 need to be stabilized and if so with what?
Also does anyone know how man ppm's I should keep the H202 at to keep the hot tub water from getting gross?
Mike Smitt
Hot Tub user - Jupiter, Florida
Hi Mike,
Check out the website www.agriorganics.com, it will give you all the info you need. Good Luck!
Mark Baker
Process Engineer - Syracuse, New York
'Hot Tub Chemicals 101' doesn't mention hydrogen peroxide. Consider other non-chlorine alternatives. http://www.hottubliving.com/spa.aspx
"Can H2O2 be used for disinfecting my pool or spa?
By itself, H2O2 is a rather poor microbiocide compared to chlorine, bromine, ozone, and other commonly used disinfectants. Consequently, it is not approved by regulatory agencies as a stand-alone treatment in these applications. However, there are a number of technologies which use H2O2 as part of the treatment program.
Concentrations > 8% H2O2 (by weight) are classified Oxidizers and are not recommended for household use. See Safety and Handling Guidelines"
--- From FAQs at http://www.h2o2.com
Don't worry about stabilizing hydrogen peroxide, that is for the manufacturers. Greater stability would make it less effective as an oxidizer. Just take precautions -- store in the original plastic bottle, avoid contact with metals (especially rusty steel), and follow the handling guidelines.
Forget ppm's, measure the oxidation-reduction potential (ORP). Buy a handheld ORP tester for $75 (works with any oxidizer). At pH 7.5, the recommended ORP is 700 milliVolts (mV). From
'ORP TESTING AND CHEMICAL AUTOMATION FOR SWIMMING POOLS AND SPAS,' NATIONAL ENVIRONMENTAL HEALTH ASSOCIATION,
http://www.energistx.com/water/neha90.pdf
Ken Vlach [deceased]
- Goleta, California
