Dephosphating formula (for zinc phosphating)
HI
please answer to me about DE-PHOSPHATING component (formula) for zinc phosphating .
thank you very much.
MOHAMAD SOLTAN REZAEI
- ESFAHAN, IRAN
You can strip the phosphate coating using the following:
Concentrated hydrochloric acid containing 20 g/l of antimony trioxide.
This solution will effectively remove the phosphate coating in a short duration with minimal attack on the base metal.
T.S.N. Sankara Narayanan
- Chennai, Tamilnadu, India
(ed.note: The good doctor offers a fascinating blog, "Advancement in Science" )
HI
please answer to me about alkaline remove ZINC PHOSPHATING component (formula).
I used of NAOH but the iron surface is the black .please help me to de-phosphating of iron.
John
- Barselona
Mixing 144g of ammonium dichromate crystals to a gallon of ammonium hydroxide works as a good stripping solution for zinc phosphate. Leave the part in the solution for a few minutes.
Ronald Zeeman
coil coating - Brampton, ON, Canada
HI SIR
I do test with ammonium dichromate and ammonium hydroxide for de-phosphating but not remove zinc phosphating.
I need to alkaline stripping for cleaned iron of zinc phosphating . please help to me component for alkaline remover for zinc phosphating .
Mohammad
- Iran
