  Thread 416/48
Printing on phosphate coated steel component
How to print a permanent number on phosphate coated steel component. The color of print required is WHITE.
Sudhakar
- Bangalore, INDIA
publicly reply to Sudhakar
By my definition of permanent, you can not. Phosphate can be abraded of without a great deal of problem. Days, weeks or years of durability would be totally dependent on how it was used.
publicly reply to James Watts
I agree with Mr. James Watts that the phosphated steel can be easily abraded with a sharp needle/object. By selectively removing the phosphate coating on the coated steel you can create a print/mark.
Phosphate coating is mainly a pretreatment and not a finish of its own. So the durability of your print/mark depends on the environment.
Where you are going to use this?
T.S.N. Sankara Narayanan
- Chennai, Tamilnadu, India
(ed.note: The good doctor offers a fascinating blog, "Advancement in Science" )
publicly reply to T.S.N. Sankara Narayanan
Try stencil electro etching.
Cair Shishani
Khair Shishani
publicly reply to Khair Shishani
Laser printing machines leave a nice white print. However it will last as long as the phosphate.
Khozem Vahaanwala
Khozem Vahaanwala
Saify Ind
Bengaluru, Karnataka, India
saify logo
publicly reply to Khozem Vahaanwala
