How to analyze ammonium content in acid zinc plating?
Q. I am plating with the mixture of potassium-ammonium chloride in an acid zinc plating process.
I know how tho get the zinc and total chloride. now my question is: How do I analyze the bath in order to get the ammonia
⇦ this on
Amazon [affil links] content?
Thanks! Saludos!
Jobshop - San Luis Potosí, México
A. You need to perform a distillation. Find a procedure for total ammonia in environmental samples, and apply that to your plating bath. You'll have to dilute the sample massively, at least by a factor of 200. The ammonia in the distillate can be determined titrimetically.
All of this is not trivial, esp. if you have no distillation set up. You might be best off sending it out to a lab.
Dave Wichern
A. Firstly, contact your brightener supplier. They should be able to provide this information. The two methods I know of are: distillation and spectrographic (using Nessler's Reagent).
Gene Packmanprocess supplier - Great Neck, New York
Thanks a lot!
Gracias!
A. Also, this analysis can be done quite easily if you have Ion Chromatography equipment.
Terry Tomt- Auburn, Washington
Q. Hi all, I have using potassium and ammonia bath. But I don't know how to analyze KCl and NH4Cl? Help me please. Thank you.
Lee WilliamPlating shop employee - Hochiminh,vietnam
October 5, 2017
