Electrolysis - Galvanizing Vs Stainless Steel
Q. If stainless steel is in constant contact with galvanized iron will electrolysis result?
Fred SteinRider Hunt - Las Vegas, Nevada
A. Galvanic corrosion requires a difference in electrochemical potential between the two metals, an ionic path for electrical current flow (corrosion), and a metallic path for electrical current flow. Picture a battery--it's good to go as soon as you connect wires (as soon as you complete the metallic path).
The zinc coating on galvanized metal is very active and stainless steel is relatively noble, so you have a strong difference in electrochemical potential. If they are wet you probably have a good ionic path. If the materials are in contact you have the metallic path.
Q. There are applications in HVAC that require an isolation of metals for reactivity.
There are common practices that are not allowed in specifications to a particular project.
My question is this, " If I weld the dissimilar metals solid to each other does the reactivity diminish to a point of longevity?"
- Spokane, Washington, USA
April 25, 2012
A. Hi, Jerry.
Unfortunately, absolutely not. Galvanic corrosion forces will only be more reliably bad.
Galvanic corrosion forces are the same system as a battery and lamp, and consist of the following arrangement: two different metals (like the zinc/carbon or nickel/cadmium in a battery), a wet ionic path (the black glop in a battery, or the salty water bridging your two materials), and the metallic connection between the two metals (a wire and lamp, or your solid welded connection).
One way to stop galvanic corrosion is to electroplate or galvanize the entire weldment with a single material, but this may be impractical in your situation. Painting it would not be as effective, but would help somewhat.
April 25, 2012
