Materials for Hydrochloric Acid 36% Concentration
Q. Good day to all.
I'd like to ask the following questions:
1. What is the cheapest but reliable material/s (pipes) for HCl 36% solution?
2. Is there a transparent material/s applicable for HCl 36% solution?
Thanks so Much
Zander Velasquez
Engineer - Manila, Philippines
A. PVC would be the cheapest. It should be used in an appropriate gage with schedule 40 as a probable minimum and schedule 80 being preferable. It must be adequately supported! It must have some room for thermal expansion! It should be protected from sunlight and from fluorescent light for longest service. The UV makes it brittle over time.
Clear PVC is available from companies like Harvel. It costs more and has a lower tolerance for UV light.
Approach with caution as you never know what level of abuse it will have in its final plant.
A. Hi Zander,
What James Watt says makes eminent sense. uPVC is A.OK for even full strength HCl.
Re a 'clear' material, consider also Acrylic tubing which, if you can get it at the same size of the PVC pipe, then it can be intercemented. Acrylics can also be interwelded to PVC, if done by an expert thermoplastic welder. Another alternative is to use flanged joints.... this infers easy replacement. Other methods of including acrylic is by using O-ring connections.
Yup, go the heaviest wall thickness....over here we call that Schedule 80
freeman newton portrait
Freeman Newton [deceased]
Q. Dear Sir,
But how about the cementing material? Any of them can stand HCl 36%? I am planning for transfer piping for HCl 33%, 35 °5 bars max.
Donno MAHARANTO
- Batam, Indonesia
July 15, 2013
