Passivation of SST, epoxy and granite
I have a 304 series stainless part that has a piece of granite bonded to it using 3M Dp-190
⇦ this on
Amazon [affil links] adhesive and I need to have the complete assembly passivated. I am not sure if the nitric acid will react with either the epoxy or the granite of affect the integrity of the assembly. Can someone help with the answer to this question?
Precision Granite Mfg - Waite Park, MN, USA
Granite is mostly silica and thus fairly resistant to acids (except HF). The 3M epoxy is unaffected by 30 days exposure to mildly acidic RMA soldering flux. Nitric acid passivation may work OK, but one test is better than 100 opinions. If problems occur, try citric acid passivation.
Ken Vlach [deceased]- Goleta, California
