How do you repair sickness in sterling silver
I have purchased several pieces of sterling silver with small scattered black dots on the surface. I understand these black spots are called "sickness".
How is the best way to remove this sickness from sterling silver?
When I tried polishing by hand it not only took forever but I had mixed results. Should I use a Dremel
⇦ this on
Amazon [affil links] tool and buff the various spots out?
Thank you for your time.
antique dealer - St. Louis, Missouri, USA
I haven't heard that term "sickness" myself, but try to clean silver by contact with aluminum in a solution of washing soda ⇦ this on eBay or Amazon [affil links] as described in several letters here, including letter 4785.
