Electropolishing bath for high strength IF steel
Respected sir/ madam,
We are involved with Electropolishing of IFHS Interstitial Free High Strength Steel. I want to know the correct composition of Phosphoric acid and sulfuric acid. I also want to current and voltage specification. I also want to know the time period to be left for polishing. Please do the needful.
Thanking you,
N.L.Parthasarathi
- Iruchirappalli, TamilNadu, India
PHi N.L. lease tell us the composition, current and voltage, and polishing time you are using, and the difficulties that you are encountering. Then hopefully someone can suggest which parameter to alter to improve that situation. Thanks.
