Rhodium plating accounting
When I do rhodium plating, how should I know how much metal I am putting on?
Antonio Panariello
- Miami, Florida
Faraday's Law of Electrolysis will tell you the relationship between ampere-seconds and the mass deposited, Antonio. There is a chart in the Metal Finishing Guidebook where, for simplicity, the various constants like density have been "worked through" so you can directly translate ampere-minutes to thickness with a minimum of arithmetic.
Another method is to simply weigh the item before and after plating.
Neil Bell
Albuquerque, New Mexico
