Cleaning of SS pipes
After welding of small diameter of SS pipes we notice the HAZ black in colour. External side we go for pick/passivation. Is there any solution for internal cleaning where areas are not reached manually? or any other solution to avoid this black colour on internal sides of ss pipes.
Sreenathgatewall - Abudhabi, UAE
First of three simultaneous responses --
Use an inert gas purge inside the pipes during welding. Avoid pickling the insides; it roughens surfaces and is very difficult to inspect. Clean and passivate the insides by pumping solutions & rinsewater. Blow dry with clean air. ASTM A380 gives useful information.
Ken Vlach [deceased]- Goleta, California
Second of three simultaneous responses --
Setting up a slow purge of nitrogen or preferably argon thru the tube will significantly reduce the black oxide formed.
James Watts- Navarre, Florida
Third of three simultaneous responses --
Purchase specification ASTM A967 and recommended practice ASTM A380 and take you pick from multiple methods of cleaning up your welds.
Joseph Lockrem- Indianapolis, Indiana, USA
