Plating of Alloy 6061T-6
I have a question regarding the plating a high aluminum content zinc like the Alloy 6061T-6. Several different process have been tried with no succes, all of them falling in the blisters or lack of adherence between the base metal and the cyanide copper layer.
Is there a specific process for this type of material?
- Tijuana, Baja California, Mexico
6061T6 is not high in zinc at only 0.15 % and it is relatively easy to plate. Finishing DOT com has literature available that tells the best preparatory cycle for electroplating or electrolessly plating onto aluminum.
I agree with the previous response. Keep in mind that when preparing aluminum for plating, the clue to success is a single, or preferably, double zincate step which is almost pure zinc. So, high zinc shouldn't be a problem. You have to find out the actual chemical analysis of your substrate and check your preplate cycle and microscopic surface condition. Look for micro pores.
