Tin/Lead Electroplate Over Nickel - Recommendations?
We have a terminal made from Alloy 52 that gets soldered to a printed circuit board, and are curious as to what the recommended/optimum process thicknesses are for the nickel barrier and the Tin/Lead electroplate. TIA for insights and assistance....
Mike McMonagleEnd User - Houston, Texas
I would recommend keeping the nickel thickness between 3 to 5 microns and the SnPb thickness of between 5 to 7 microns.
Poobalan- Singapore
