Anodizing stripping
Hello
I was wondering if you could help me with an anodizing question.
I have 8 chairs, produced in the 40's -50's made from aluminum square tubing, Goodform or Emsco the Manufacturer, the remaining anodizing (much has worn off) has turned yellow. I have trying removing it with 00 steel wool this on eBay or Amazon [affil links] and you can imagine the work involved.
I was going to take the chairs in and have them stripped at an Anodizer, however, there are a few steel nuts on the chair that I am afraid will be damaged in the "Dip tank" stripping and anodizing process. Can you recommend an "off the self stripping agents". Thanks
Derek Davis
- Troy, Michigan
Hi, Derek. Anodizing can be removed with oven cleaner this on eBay or Amazon [affil links] . This is nasty stuff even when used as intended; when used for purposes like this for which it wasn't intended, it can be even nastier. So goggles this on eBay or Amazon [affil links] (not safety glasses), rubber gloves this on eBay or Amazon [affil links] , plastic/rubber apron this on eBay or Amazon [affil links] , and respirator should be used, outside, with plenty of ventilation.
The oven cleaner will also attack the raw aluminum, so leave it on only long enough to remove the discoloration that you are after. Good luck.
March 7, 2009
