New finishes for magnesium alloys -- anodizing and chromating
Q. I am currently doing research on Mg alloys in watch making. I want to know the different finishes available. The finishes need to be decorative, corrosion resistance, hypo-allergic and have reasonable mechanical properties. Any comment on the subject is appreciated.
Doris Wong- Hong Kong
A. You can either anodize it or put a chrome conversion coating on a magnesium alloy. You can also paint after treating the surface with a chrome conversion coating.
S. Y. Yuen- Hong Kong, China
A. There are new ceramic oxidization coatings which produce extremely high hardness and corrosion resistant surfaces on Mg. This can be polished to produce a pleasing appearance (depending on alloy) and accept paint easily as well as certain dyes.
Trevor Amos- Southampton, England, UK
by Dow Chemical Co.
is sometimes available on
AbeBooks,
eBay, or
... but if not, you can find libraries which have copies on WorldCat.org
A. Hi, Doris. We have a review of magnesium finishing on line here: "Finishing of Magnesium". Further, magnesium can be electroless nickel plated.
If you can possibly find it, try to get hold of the "Dow Handbook on Magnesium Finishing" . Good luck.
March 6, 2009
