  Thread 409/26
Methanol damaging epoxy paint
I have an aluminum product with the following finish;
Chem film per ASTM B449 , class #3
Prime, one coat of MIL-PRF-85582 [from DLA] , Type 1, class C2
Top coat per MIL-DTL-46168, Type 2
If the painted (cured) product is exposed (submerged) to methanol [affil links] for 5-10 minutes the paint and primer will blister and lift of the base metal in sheets (paint and primer stay bonded to each other). The paint is soft when scrapped with finger nail.
Is this expected with methanol or is the paint suspect. Ethanol has no effect, Acetone is about the same as methanol. I am heat curing a few samples to see if maybe the paint is not fully cured.
William J. Sampson
publicly reply to William J. Sampson
