High temp non-stick and durable coating?
I am looking for an extremely non-stick coating. That can withstand 350 degrees. Also would like it to be fairly durable. Teflon has been tried with moderate results. However, a bare metal tool used on the part scrapes the teflon off. Something more durable is needed if possible.
Ron Forshee
Aerospace Mfgr. - Los Angeles, California, USA
I suggest Electroless nickel plating that has co-deposited PTFE (Teflon) particles. Check your local plating company.
don baudrand
Don Baudrand
(Don is co-author of "Plating on Plastics" [on Amazon or AbeBooks affil links]
           and "Plating ABS Plastics" [on Amazon or eBay or AbeBooks affil links])
Hello Ron,
Poeton sells a good polymer coating called Apticote 200. For high temp ranges they make a 200A or 200L which comes in brown and green respectively. Good Luck!
Mark Baker
process engineer - Malone, New York
Hard Chrome. Excellent non-stick and high temperature properties up to 300-350 °F. Also possible Electroless Nickel, plain or with teflon particles.
Guillermo Marrufo
Monterrey, NL, Mexico
Why not to try hot enamel coating. good luck
Cair Shishani
Khair Shishani
Sputter-deposited molybdenum disulfide (MoS2) should work in your application.
jim treglio portrait
PVD Consultant & Wine Lover
San Diego, California
FOR THE TEMPS AND THE HARDNESS NEEDED, THERMO DIFFUSION GALVANIZING SHOULD DO THE TRICK. WITH 45 TO 48 RC HARDNESS. THIS A PATENTED ZINC POWDER THAT VAPORIZES ON TO OR INTO ANY FERROUS PART AND WILL FOLLOW THE CONTOURS OF THE PART EVENLY INSIDE AND OUT. CAN BE USED PLAIN OR WITH A VARIETY OF TOPCOATS.
THANKS
W.C.LITZINGER
- FAYETTEVILLE, ARKANSAS, USA
