Line problem on ABS plating
Sir
WE do plating on ABS parts but we face problem of straight random line on plated jobs. These problem arise when we give Ni strike before cu & if we do direct cu plating after electroless Ni , we don't get the line problem. This line is not visible on moulded parts. Also we use same tank for both Ni strike & semi-bright plating after cu.
Amol Subhash Khairnar
First of two simultaneous responses -- 2006
Hallo Amol,
This Vishal, your friend from Aurangabad.
For line problem you to increase Additive brightener in nickel & copper plating.
Vishal Duse
Second of two simultaneous responses -- 2006
Do direct cu plating after electroless Ni , This is good for you are surround job.
OK
PANKAJ PATIL
PANKAJ PATIL
