No cost, no passwords, no popups
(earnings from 'affiliate link' purchases make the site possible)
Rust treatment for historic cast iron on stained glass window
I am currently invovled in the restoration of a historic stained class window. All of the cross members are decoratively painted cast iron. I am looking for a method that will remove/neutralize the rust in place. I do not think blasting is an option. I would appreciate any help anyone can give. I have researched products like Loctite's rust converter this on eBay or Amazon [affil links] but I am looking for something that can complete neutralize the rust and then be painted over.
David Greene
Remove rust with citric acid this on eBay or Amazon [affil links] 5%(or with 5% ammonium citrate solution,pH 3,5),then you can treat it with 20 gm tannic acid this on eBay or Amazon [affil links] /15 gm phosphoric acid/1 lit water solution.That is simple and cheap do it yourself rust converter this on eBay or Amazon [affil links] .You can try Conservation on Line website too(http://palimpsest.staford.edu),they have very good specialized discussion list.Good luck and hope it helps!
our company has an organic/plant-based rust converter this on eBay or Amazon [affil links] which safely and quickly neutralizes rust and renders the treated surface self-primed for paint. Please call Barry. good luck
Barry Feinman
Barry Feinman
BarrysRestoreItAll
Carlsbad, California
barrysrestoreitall
