Polishing raised lettering
What is the best way to preserve the raised lettering of a part number on an aluminum casting while polishing to a mirror-like finish and at the same time removing pock marks?
Carter John
Probably the best way to achieve the finish you want is to run your parts in a dry polishing organic mix using mass finishing equipment.Any method you do choose will have a problem with raised lettering, but dry organic processing will do a better job of blending and still obtain good light uniform results.
tony kenton
AF Kenton
You and your customer should talk about the possibility and benefits of changing to depressed lettering.
Guillermo Marrufo
