How do you remove oil based primer drops off of concrete?
I need to know how to remove oil based primer drops off of concrete?
Briana WhittenOctober 27, 2008
I would like to ask if anyone knows how to remove oil based primer from concrete pavers. My 18 year old grandson figured he was too good to take the necessary precautions. At this point, I assume the only way is to put down all new pavers to replace the ones with paint on them?
Anna DeGrangeRegards,
October 29, 2008
Hi, Anna. Turpentine ⇦ this on eBay or Amazon [affil links] or mineral spirits ⇦ this on eBay or Amazon [affil links] is the traditional remover for oil-based paint, so that would be worth a try. Of course, if the pavers are bare porous concrete you probably won't be able to get all the paint off, and if they are tinted and sealed, the turpentine may damage the seal coat, but it's worth a try.
