Coatings for Aluminum Busbar
What coating and post-treatments are required for aluminum busbar and joint aluminum busbar
Thanks for your help.
Often the whole bus bar is electroplated with copper first. Then the whole bar or just the ends may be tin plated or silver plated, or joined with no plated surfaces, just a joint compound.
When I electroplate aluminum bus bars with copper is there galvanic corrosion?
I have read something that the aluminum in contact with copper produces galvanic corrosion
I need electroplating bars conductors of energia electrica
2"x1/4"
4"x1/4"
2"x3/8"
4"x3/8"
thank you
