Can I plate tin directly to 304 stainless?
I have an old print that requires 0.011" thick, 304 stainless, with a woods nickel flash, then electroplated with .00008 - .00024 Tin with 2% to 3% lead electroplate. Is the woods nickel flash or strike necessary? What will be the results if we don't strike?
Rob Withrow
No, you can't skip the Wood's Nickel. The result would be virtually zero adhesion. Electroplated coatings must grow on active metal, whereas stainless steel immediately passivates. The Wood's nickel is a way of simultaneously attacking/removing that passive layer while depositing a fresh nickel layer.
April , 2006
