Painting on Gear Box
We are Tablet Press manufactures,in the machine we have designed a gear box of worm and worm wheel type.The Gear Box is Round Enclosed Casting of Material,S.G.Iron
My question is what type of paint process to be carried out on Gear Box,so that the Heat Generated inside the Gear Box which can go up to 70 °C can be dissipated without paint obstructing the heat transfer process.The other criteria is the paint should also sustain at such high temp.
Deepan
Check out Aremco. They have various products which I think could work for you.
Jim Wood
